Parrot of Doom
Well its a bit weird, so I'll explain. The car is a 1997 W210 E300TD saloon with 165k
Basically, twice now (since I bought the car in November), after full acceleration and then backing off immediately, I've felt the car lurching - as if its braking unevenly. This has been completely random, every other time the car behaves perfectly.
The first time was onto a motorway, the engine was probably up to temperature (was a while ago), I flew up the slip road, and straight away had to slow for 40mph roadworks. While braking, the car seemed to be momentarily applying the brakes and then releasing them.
The second time was today, engine running for about 5 minutes, I accelerated hard up to about 45mph and backed off to slow down (no brakes), the car did it again.
Now on both occasions I don't particularly remember what the tacho was doing, but I don't remember the engine changing pitch - so I don't think its the gearbox making funny changes.
So, I suspect that either the brake assist is doing odd things, or that I'm getting momentary lapses in the fuel supply to the engine - or perhaps something else that you guys might suggest?
Is there a primary fuel filter close to the tank that I might change? Perhaps I should change the diesel I use? I've already done the one in the engine bay, and the engine oil. Next is the gearbox fluid, but the gearbox makes good changes - however when the car is cold in the morning the gearbox gets a bit confused, and won't change from 3 to 4 without see-sawing back and forth between the two gears. Once warm, its fine. I'm hoping that a fluid change will sort this behaviour out.
