Dr-Nab
On the GL350 CDI It's a '59 facelift model with the full LED rears (and still under warranty).
The right rear indicators have jacked in.. still works but flashes randomly - fast then slow then constantly on rather than how it would normally work, left side are perfectly fine. It's only 2 of the 10 LEDs (the one in the middle on each row) that have stopped working. Had a look to see if I could pop the light cover off and replace the LEDs but they're nicely bolted in and I can't get to the upper bolts unless I take the trim out of the side of the boot.
By looking at the back of the cluster, the loom etc from what I could see I don't know if it will be possible to open the unit and replace anything without breaking any seals - as previously with replacing a normal halogen bulb it's blindingly obvious on how to do it.
Question I have is are the LEDs lights covered by warranty? Can the individual LEDs be replaced? I imagine they're set up in a similar manner to other MBs that have LED lights so just looking for some insight if anyone else has had any issues with theirs.
I know some dealers are funny on bulbs and see them as consumables but LEDs are supposed to last a whole lot longer than 2 years/20k miles.
Any help would be great!
Thanks,
Nab
Thanks,
Nab
