markjay said:If you have any familiarity with the brands, this would be helpful. The contractor basically said "Daikin is best, but Fujitsu will give you same quality and cost less".
If only.Put the rubbish one up the end where the women will sit and the good one up the other end.
Sorted.
In a previous facility, one of the women constantly complained of being cold so she had a fan heater under her desk which solved the problem - for her, anyway. The side effect was that the rest of the office froze because she was located right next to the thermostat, which switched off as a result of the additional local heat sourceHR17 said:Stick with a fan/fan heater combination so they can keep themselves happy.
You really couldn't make it up...
