PaulE230
- Mar 27, 2007
I have changed the bulb and all the wiring looks fine ??
check for voltage with a test light. Could be a bad earth or a split in the wire.
elaborating to what BlackC55 as said if they are corroded or have a thin layer on the connectors that may prevent current flow then try sanding the connectors slightly
As BlackC55, it will be the black connector onto the light pod. It will be very stiff to remove but once cleaned up the light will be Ok.
