Offside speakers
Adesou
E320 cdi
Hi, non of my offside speakers are working, I have the Harmon Kardon system, any advise appreciated......
It is strange that one side would fail (could cope with one channel failing, but with HK that is lots of channels of the amp).
Are you sure the balance is just not set all the way to the working side ?
Richard
Morning mate, yep played with balance and fader, tried CDs in multi changer and head unit, not tried radio yet but can't see that making any difference, tried normal sound setting as well as logic 7, stumped......
Hi
Ok, my suspicion is now the amp (based on why would lots of speakers on one side fail together, there may be some common power-supply in the amp) - but diagnosis without actually seeing it is difficult.
Where are you ? If you go see Alfie at Mercedes Retrofit Specialist - Comand.co.uk he even keeps a spare W211 HK amp in stock
Cheers
Richard
Yep, had a chat with your guy at Command, similar prognosis, so going to find someone a bit more local to me who can run a meter or something over it, I am down in Devon, thanks for your help, will post as I know more....
