golden1245
- Sep 6, 2011
- 1999 C230K Sport
My '99 C230k has been running quite well up until now...but I've just been hit with 3 error codes, plus my engine and transmission mounts desperately need to be replaced...I wonder how much this is all going to cost.
The 3 codes are:
P1519 Camshaft timing function chain, right link control.
P0105MAP Circuit
P0410 Secondary Air injection system
I have a brand new Cam Positioning sensor so hopefully that will solve the P1519 code, but i have a feeling it has to do with something else because a faulty cam position sensor has its own code. I'm also confused about the MAP circuit and Secondary Air injection system codes.
I did discover a worn out hose around the MAP sensor area which is leaking air and making a prominent "pzzzzzzing" sound when the engine is on, could that have anything to do with this?
I know these things are difficult to diagnose but thank you in advance for reading guys
Olly
The 3 codes are:
P0105MAP Circuit
Olly
