Mar 30, 2013 #1 K knz1029 Member Joined Sep 18, 2012 Messages 31 Location northern ireland Car 2003 c220 cdi coupe 143bhp I have just noticed oil and air spraying from around first injector on my 2003 c class coupe CDi, please help how easy or hard is it to fix Last edited: Mar 30, 2013
Mar 30, 2013 #2 grumpyoldgit MB Enthusiast Joined May 7, 2012 Messages 2,603 Location Stourbridge Car C270CDI Avantgarde SE Forgive my doubts, but I'm pretty sure that you only get coil packs with petrol engines. One per spark plug is the norm I think. With CDI (diesel) engines you should have glow plugs and injectors. Edit: OP has edited his original post and removed 'Coil Pack' from his text. I haven't lost the plot Last edited: Mar 30, 2013
Mar 30, 2013 #3 OP OP K knz1029 Member Joined Sep 18, 2012 Messages 31 Location northern ireland Car 2003 c220 cdi coupe 143bhp Yes your most probably correct haha, do you know how to fix oil and air spraying from the first one of them on top of engine
Mar 30, 2013 #4 grumpyoldgit MB Enthusiast Joined May 7, 2012 Messages 2,603 Location Stourbridge Car C270CDI Avantgarde SE Injectors usually require special tools to remove them after years of prolonged use, so I would suggest you take it to a good local independent Merc specialist to have it done.
Mar 30, 2013 #5 OP OP K knz1029 Member Joined Sep 18, 2012 Messages 31 Location northern ireland Car 2003 c220 cdi coupe 143bhp Please help oil and air spurting out 1 of the injectors on my 2003 c class CDi
Mar 30, 2013 #6 OP OP K knz1029 Member Joined Sep 18, 2012 Messages 31 Location northern ireland Car 2003 c220 cdi coupe 143bhp So does it need a new injector or maybe a seal or something simpler
Mar 30, 2013 #7 Stratman MB Enthusiast Joined Jun 15, 2003 Messages 5,822 Location Sunbury Car W203 C200 CDI '04Estate It sounds like the seal has gone on the injector. IF that is the case, you need to remove the injector, recut the seat, renew the crush washer and replace the injector following the correct procrdure.
Mar 30, 2013 #8 OP OP K knz1029 Member Joined Sep 18, 2012 Messages 31 Location northern ireland Car 2003 c220 cdi coupe 143bhp How do I recut seat? And do I ask for crush washer at automotive shop ?
Mar 30, 2013 #9 markjay MB Master SUPPORTER Joined Jun 24, 2008 Messages 48,782 Location London Car 2022 Hyundai IONIQ 5 RWD / 2016 Suzuki Vitara AWD What engine does the car have - i.e. is it 200CDI / 220CDI / 270CDI / 320CDI etc?
Mar 30, 2013 #10 OP OP K knz1029 Member Joined Sep 18, 2012 Messages 31 Location northern ireland Car 2003 c220 cdi coupe 143bhp C220 CDi 143bhp
