Sam87
Hi everyone,
I noticed the oil sump was a bit wet and decided to take it off, clean it and seal it up as there is no gasket for the sump.
The technical data says this engines take 9L of oil with a new oil filter but when i put 9L the computer in the car said to add another 2L
I added one more litre of oil as when taking the sump off it's normal that you'll get a bit more than 9L of oil coming out.
Now that the car has 10L of oil the computer still says to add 1.5L more
I don't know what to do as having too much oil is just as bad as having no oil.
What do you guys recommend i do?
I have changed the oil many times on this car and it normally takes 9l
