Oil cooler help....!
Discussion in 'Parts, Maintenance & Servicing' started by LewisMercVito, Jul 12, 2018.
  1. LewisMercVito
    LewisMercVito New Member
    1
    Jul 12, 2018
    Camberley surrey
    Car:
    Vito
    Hi Guys, first post here, hoping you can help.
    I've recently become the owner of a 2004 vito 111 Automatic transmission.
    Annoyingly i noticed 2 small oil leaks very soon after buying, which seem to be coming from the ends of the pipes which go into either end of the oil cooler (in front of the rad, right at the front)
    Will changing the pipes resolve this or is it a problem with the oil cooler itself?
    Also where can I buy the replacement pipes? I've sourced an oil cooler if needs be but no body seems to stock the pipes.
    Has anyone done this? Is it a nightmare job? (looks quite straightforward and not really keen to spend 500 quid that I've been quoted!)
    Many thanks for any advice
Share This Page
