Oil&Filter change 220cdt (2014 ) EClass
14emerc
E class 220cdi
I have a Pela extractor that I use for the wife's car and would like to do a change on mine, so can anyone point me as to how the engine cover is removed and then, is the oil filter easy seen and changed.
Pete
Would you not void the warranty servicing it yourself?
Good point, my other new cars, had a couple, and I've always change the engine oil. Still would like to do so but just need to ensure that I am able to lift off the cover without doing any damage. Then find where the filter lives.
Pete
Someone must be able to post some info....please
Sorry, there is no document on WIS. Must be either very easy or obvious!
If there are no bolts, I would suggest it pulls off
Little up date for anyone who like me, changes the oil mid service. There is only one locking screw. This is right at the front of the cover. Turn it 90 degrees and simply lift off the cover. The oil filter housing live under this cover and is easily seen.
Pete
