Oil & fluid quantities?
Mickee92
Newcastle
W204 C63
Car is a w204 c63 and I will be buying Brake fluid, axle oil & engine oil to service my car and don’t know how much of each I will need.
So questions I have is how many litres of each do I need? I’ve managed to find somewhere that says 8.5 litres for engine oil is that correct?
Also when bleeding the brakes can I use normal methods or will I need STAR to do the bleeding?
I’ll be buying my service items from Mercedes unless anybody has a reason why I shouldn’t and should opt for something else.
Normal bleeding methods on yours as it doesn’t have SBC brakes
Spot on cheers, good to know!
any idea on the fluid quantities?
I'm not 100% sure, but when you order the stuff from Mercedes then give them your reg and explain and they will look the quantities up on their system. :)
I highly recommend Mercedes Benz of Edinburgh - they sell on eBay too.
So finally had the chance to pick up some service items from the Mercedes dealership.
A000989520413. 10 litres of oil - apparently needs around 8 litres
A002989020309. 1 litre of rear axle oil - 1 litre seems a small quantity??
A000989080713. 1 litre of brake fluid - asked for another litre as 1 seems very little as I’m used to using 2 in the past.
A0001803009. oil filter
all came to £137.
A002989020309. 1 litre of rear axle oil - 1 litre seems a small quantity?? - GIVEN THE WRONG OIL. Needs 1.2 litres of this instead.
Genuine Mercedes-Benz W204 C-Class C63 AMG Limited Slip Diff Oil A001989520310 | eBay
all came to £137.
