Oil from both front wheelarches...
Discussion in 'Engine' started by amwebby, Jan 12, 2009.
  1. amwebby
    amwebby Hardcore MB Enthusiast
    1,440
    Aug 9, 2006
    Thorpe Bay
    Car:
    CL500
    ... spots of oil have just appeared on my front driveway after a trip to London at the frant and rear ends of the front wheelarches. Any ideas where this might come from.
    Going past the Tower of London I hit a large piece of masonry on the road with quite a thump (bloody cowboy builders). Could this have damaged anything?
  2. stats007
    stats007 MB Club Veteran
    5,880
    Aug 10, 2003
    Hampshire
    Car:
    575M
    You have ABC don't you?
  3. OP
    OP
    amwebby
    1,440
    Aug 9, 2006
    Thorpe Bay
    Car:
    CL500
    Yes. And that means?
  4. grober
    grober MB Club Veteran
    27,600
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    First thing to establish is whether its engine oil or hydraulic fluid. Take a look at the engine dipstick end, the brake fluid and the power steering reservoirs to get an idea of the colour, viscosity, smell and feel on your fingers of the various fluids. Check the levels while you are at it. Then try and determine which one you have got in the wheel arches. Take a good look round the engine compartment in daylight to see if there are any signs of leaks. Fluids can thrown out to the sides by the fan or poly V belt when the engine is running away from the leak source.
    p.s. for peace of mind you really need to get the car up on a ramp ASAP to check for any damage underneath.
  5. OP
    OP
    amwebby
    1,440
    Aug 9, 2006
    Thorpe Bay
    Car:
    CL500
    It was black, very black.
    Just did a quick visual check, having been for a run locally. No more oil spots, wheelarches are dry and no obvious signs of oil splashing about in the engine bay.
  6. popuptoaster
    popuptoaster Hardcore MB Enthusiast
    804
    Oct 2, 2008
    Essex
    Car:
    2000 E55 AMG Estate
    Are you sure it wasnt just crappy oily water from driving about in london?
  7. OP
    OP
    amwebby
    1,440
    Aug 9, 2006
    Thorpe Bay
    Car:
    CL500
    That seems to be the case...
  8. steptoe
    steptoe Member
    48
    Apr 6, 2004
    Did you run over any cats/mammals/rodents ? :D
  9. SG CL500
    SG CL500 Hardcore MB Enthusiast
    774
    Mar 19, 2005
    Cambridgeshire
    Car:
    FFRR TDV8
    I get exactly the same after having driven on cruddy roads too - spooked me the first time I saw it as well. Do keep an eye on things but in my case at least it turned out to be nothing more than detrius collected from the road dripping off the wheel arches.
  10. c240yaz
    c240yaz Hardcore MB Enthusiast
    1,096
    Jun 21, 2007
    Could it be Tarmac residue ?
Share This Page
