Coddie
Hi apologies for starting a new post on this one, I've seen other threads on this issue but cannot find them again.
its regarding the oil leak from the engine that contaminates the wiring loom and ecu, causing faults to show with the oxygen sensors.
As it seems to be a common fault, were the affected vehicles ever recalled?
secondly is there a way of preventing the contamination from happening, some adaptor or similar?
As yet, touch wood our w203 seems ok, but a friends has shown this problem, I was reading somewhere on the site that it's possible to clean the loom and ecu of the oil, is this correct, and if so what does anyone recommend to do the job?
Thanks for your time.
