Oil in radiator expansion tank.
Datadogie
Aberdeen Scotland
C180 Komp 2005
Think I will be scrapping my car. Last MOT advisory for rust on rear subframe. Now this. It will be more money than the car is worth to fix. Radiator.jpg
Could be autotransmission fluid if the tranny heat exchanger is in the radiator? IF THE AUTOTRANS IS STILL WORKING OK a radiator swap and new gearbox fluid might be a relatively cheap fix?
I think the oil filter housing has an oil/coolant heat exchanger on it-- the gasket between this and the block is known to go
whats the engine oil on dipstick like?
For Mercedes M271 W204 C180 C200 E200 SLK Oil Filter Housing Gasket / Radiator Oil Cooler Gasket Kits OE: 2711840280
I think that cooler is for diesel. But I've made my mind up she's going. No point in spending good money after bad. I fear it will be something else next month.
