Oil Leak,Intercooler Pipe
Paulm711
Leicester UK
Chrysler Crossfire
Hi,I have what I beleive to be an oil leak from the intercooler pipe to turbo on my 2010 C350,I beleive the o rings fail on them? so I've ordered a new one and also a new mass airflow sensor pipework to turbo seal( the big orange one) Anything else I need or to look at while doing the job?
There is a green o ring on the top of the intercooler pipe and a black o ring on the bottom end .
You'll want to do the pcv breather pipe orange seal also. Fits on the left next to the main turbo seal.
Those pipes a very common to leak. Often changing the seal doesn't stop it.
Have you checked the hose for a split on its lowest point, it’s a classic failure point, as well as the o rings.
Thanks for the oring and seal advice,changed the green oring which actually had had a black oring in it and was split,changed the big orange seal on the turbo as well and found that the pipe from the PCV into the MAF was split,so I've temporarily taped it up and need to order a new one,does it come with the sensor in it as well as the orange seal on it? Just a reminder it's a 2010 C350
The pcv tube is a complete thingy a foot long with orange seal attached , (sensor in the middle )
Try MB Newcastle eBay page first , to get the correct MB part for your car
