Can anyone tell me what's going on .IV got an oil leak also where it seems to be there's a mass of air flow blowing out from almost centre top of engine not sure if it's just air flow that runs through ..very slight at top right of engine IV took pics try to upload .car got hot yesterday smelt oil coming out from bonnet on top left corner and smoke .inside noticed oil and in different spot just to right next to dip stick I found a teas spoon worth of anti freeze sitting in gulley around a bolt ?? Cleaned this away .next morning nothing evident of any problems .The gully was dry .so started it up let it run for half hour .temp on 80 just over .nothing happening on engine just this airflow coming through So I took it for a miles drive .temp stayed the same but back home I could smell oil.It seems to be where the airs coming from .Also no warning light to tell me water was low which means when it was super hot IV lost water .ie the gully I put water in to correct level this morning before I started and there's no water loss .Any help would be very appreciative and am an avid learner.
