Baldbloke
Had a bit of a leak and mist over the front of the engine that I feel I need to try to cure. It appears to be coming from a join where a hard plastic canister joins a rubber pipe from the inter cooler and the alloy pipe that leads up to the Garret turbo.
The car has a mere 69,000 miles on her. I
I have a few questions please.
Is there a filter or gauze in the plastic canister?
Is this a common issue?
The engine has suffered from momentary dying on harder acceleration before its fully warmed up. I don’t hammer it while it’s cold, but have a dodgy junction close to home that needs a smart departure. Could a leak here be the cause of this flat spot?
I’m doing quite a bit to her at the moment and have eventually got my rear air suspension to work (with some help from here[emoji1303]) and am currently replacing some brake pipes before an mot test. An idea of what to look for would be much appreciated.
Here’s a couple of pictures
