Oil pressure
Suzanne
London
1988 190E 2.0L Manual
I just bought a 2.0L 1988 190E last friday, until today the oil pressure gauge was working as it should, at idle it sat on 2 and shot up to 3 when I touched the pedal, but today its just been on 3 the whole time, even when idling. Is this ok or could something be broken? any help will be much appreciated, cheers:D
Mine sits on 3 all the time, a few seconds after startup, don't worry yours sounds fine.
It should be slightly lower on idle, do you know when it was last seviced as the Oil and Oil filter could need changing.:confused:
Thanks for replying guys, I dont think its had a service for 2 years :crazy: and I dont think the guy I bought it from was the type who would change the oil himself. What Ill do is change the oil and filter and if it still sits on 3 then I take it its ok??
Might be best to ask for an engine flush also if it hasn't be changed for a couple of years,won't do it any harm. good luck
