Hi NeilMerc,View attachment 75591 I recently did an oil and filter change on my 2009 ML280 diesel.
My icarsoft now gives the following for oil quality.
What is good and what is bad??
I didn’t look at the reading before the oil change!
Cheers buddyFor reference, at 3K miles of mainly short journeys since the last oil change, mine shows an oil quality of 2.22, so I guess it goes up as the oil ages.
On the iCarsoft 980, it's under "Diagnostics" (not OBD diagnostics), then 'Motor Electronics" -> "Actual Values" -> first item (sorry, forgot the name). I suspect it's present in a lot of the ME actual values.
Ian.
My ALFA has something very similar....a few years back when I was getting near oil change time a message popped up on the dash to warn me that my oil was degraded....so I changed it slightly early.....never seen it since though. I had to use my ALFAobd software to delete the message as it did not go after the change.Mercedes used to employ the B40 sensor which measured 3 things oil level, oil temperature and oil delectic constant [conductivity] via 3 separate sensors in one unit. AFAIK the di-electric constant measurement reflected the water content of the oil and thus its lubrication ability as markjay said.
http://www.benzworld.org/forums/att...il-sensor-how-does-work-w208-b40-function.pdf
If I got this correct a reading below 5.8 is OK. I can only suggest you monitor the reading as the oil ages to see which direction it goes in?
ps this may not even apply to your car
