Old boiler !
Discussion in 'OT (OFF Topic) Forums' started by Gareth Kent, Aug 15, 2017.
  1. Gareth Kent
    Gareth Kent Active Member
    102
    Dec 30, 2014
    Hello chaps. Any heating engineers on here please? Am looking for guidance/suggestions.
    The 30 year old boiler in my house has just packed up as the gas injectors are shot and are no longer available as replacement parts as such I am told full boiler replacement is required. My excellent but old school local heating engineers have exhausted their parts suppliers and even checked their shed!
    The current boiler is part of a gravity system with water storage in the attic, with a separate copper hot water tank in a landing cupboard. The boiler is cited in the kitchen, floor mounted with the flu going into the central chimney.
    That in itself is not much of a problem as I am locked in with a builder to begin an extension and returb of the house starting in January and had anticipated and budgeted for a new boiler and re-plumb.
    As part of the refurbishment works we will have the new boiler location moved to a utility room in the new extension as part of a new system.
    My issue is one of timing in that if I get the heating system changed now I will need to incur the cost of changing all the pipe work and associated disruption, only to have to do it again when we move the boiler as part of the refurbishment.
    My questions are:
    - Does anyone know or can they suggest a way of just replacing the existing boiler like for like and keeping the existing location and pipe work as an interim measure, and if so is this even allowed/safe under current regulations ?
    - Or is there such thing as used boiler parts, akin to parts from a breakers from which I can source the injector and soldier on hoping the boiler makes it through the winter until I move out and refurb ?
    The old boiler model and part required is:
    - Ideal Standard Boiler 80N
    - Ideal Standard Injector part required is 002610
    I have done a few web searches and can not find a clear answer on this so thoughts / suggestions welcomed.
    Sent from my iPhone
  2. geraldrobins
    geraldrobins MB Enthusiast
    1,441
    Jan 26, 2013
    Car:
    VW Golf, past c200cdi
    You should be able to connect a new system boiler to your existing pipework but I believe the system will need to be power flushed for the boiler warranty. Presumably you can fit a wall mounted boiler in lieu of floor standing?
    My son had new parts fitted to his 30 year old Ideal Standard boiler recently but it was only a thermostat and spark igniter.
    1 person likes this.
  3. AMGeed
    AMGeed Hardcore MB Enthusiast
    12,787
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2014 E63 Biturbo
    I doubt it will be as easy as a straight swap with a little extra pipework.
    The regs have changed a lot since your original boiler was fitted, even down to the diameter of the incoming gas pipe from meter to boiler. You will have a magnetic filter fitted and the boiler is vented outside differently to the old system.
    It would be nice to think you can source the parts needed to keep your old boiler going until your refurb takes place.
  4. Petrol Pete
    Petrol Pete MB Enthusiast
    3,481
    Nov 11, 2016
    Petrol stations ...everywhere
    Car:
    C55 AMG Wagon
    30 years old ? when was the last time it was pressure tested ? Not sure I would want to keep it.
    What does your insurer say about it ? The floor standing ones we have at work have to be insurance checked every year. Different from domestic I know, but it is done for a reason.
    Good luck
  5. Chrishazle
    Chrishazle MB Enthusiast
    3,392
    Nov 13, 2008
    Nr Ashford, Kent
    Car:
    2008 S204 C220CDI Elegance Estate Auto, 2008 R171 facelift SLK280 Auto.
  6. Happytalk73
    Happytalk73 MB Enthusiast
    5,682
    Sep 10, 2015
    Uk
    Car:
    Vito
    Gareth, are you in Kent as your name suggests?
    If not, where are you?
  7. Dryce
    Dryce MB Enthusiast
    7,182
    May 17, 2006
    Car:
    Does your hot water tank have an immersion heater - or can it be fitted with one? If so you could use that as an interim HW solution.
    Would electric heaters be acceptable for heating the house for the early (usually less cold part of the winter).
    Just how well these work is dependent on perceived comfort requirements and the build of the house - but I had a relative who lost the use if his boiler for a month and went to Argos and bought a batch of cheap heaters - we were surprised by how toasty the house was - but that was a relatively modern build.
  8. OP
    OP
    Gareth Kent
    102
    Dec 30, 2014
    yep am in Kent.
  9. OP
    OP
    Gareth Kent
    102
    Dec 30, 2014
    Thanks - we have an immersion which is fine for hot water but will need proper central heating come mid to end of sept.
  10. OP
    OP
    Gareth Kent
    102
    Dec 30, 2014
    Serviced and Tested annually with CO2 monitors in place. Will check ins docs now you mention it.
  11. OP
    OP
    Gareth Kent
    102
    Dec 30, 2014
    Me too. That's the ideal scenario. It's a £10 part that went out of production in 2014 with no cross over parts compatible (according to the manufacturer). I am calling suppliers but all coming up blank so far.
  12. grober
    grober MB Master
    27,641
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Have you tried searching via the appliance gas council number GCN rather than the manufacturer no?
  13. OP
    OP
    Gareth Kent
    102
    Dec 30, 2014
    yes indeed. Identifying the part is easy, it's just no longer made so best chance is if it's lying in a stockroom somewhere, or available as a working used part.
  14. Darrell
    Darrell MB Enthusiast
    3,911
    Dec 15, 2006
    Back in Mill Hill but sometimes in Skiathos
    Car:
    A Jaaaaag, 2016 Dacia Duster and a 2004 Carrera (996)
    I would go with what Dryce said.
    In my experience once the builders get stuck in and start mucking about with an ageing system, maybe draining it and removing rads it'll never work properly again.
    Go to Screwfix and cheap a load of leccy heaters.
  15. grober
    grober MB Master
    27,641
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  16. Smart320
    Smart320 MB Enthusiast
    2,181
    Feb 10, 2017
    Carmarthen
    Car:
    R172 SLK 55AMG , Toyota RAV4 3 dr
    Agree! Had the same problem when we did a major house renovation and moved from external 8 yr old oil combi boiler to a system boiler in studio 3 m from the main house. Once the combi was drained to change the pipe work it could not be restarted. After 1 days labour we gave up and used immersion and electric rads for 6 weeks in December/ Jan .
    You will be amazed how well you can keep warm using oil filled rads plus a Dyson fan heater for fast heating in lounge. If u cannot find the part you need this is the way to go
  17. Ted
    Ted MB Enthusiast
    5,725
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    Markjay has a boiler going cheap in the classifieds.
    May be cost effective.
    2 people like this.
  18. Piff
    Piff MB Enthusiast
    2,121
    Feb 24, 2005
    Suffolk
    Car:
    Mitsubishi L200 Barbarian, A207 E250CDi Cabriolet Sport, R171 SLK280
    I believe that any new boiler fitted now has to be a condensing boiler.
  19. clk320x
    clk320x MB Enthusiast
    9,901
    Sep 27, 2016
    Midlands
    Car:
    W211 E320 CDI, W212 E250 CDI, W203 C32 AMG
    Electric fan heaters for £15 a pop in Argos
    Do an excellent job i often use it rather than central heating for fast heating when I get back and to keep your feet nice and toasty
  20. geraldrobins
    1,441
    Jan 26, 2013
    Car:
    Yes I believe that is correct but it doesnt have to be a combi and can be wall or floor mounted.
Tags:
Share This Page
