popuptoaster
Hey all, it's been a while since I've been on here!
I have an 04 Sprinter 416 4x4, it's an ex forces ambulance that has only covered 22000 miles but i managed to kill it.
It had been standing for a long time and I just started it up and drove it 200 miles whereupon it developed a sudden death rattle, then went crunch as something broke and then seized solid.
I am fully aware I am an idiot and should have changed the oil and fluids before driving it. in fact it's taken me about 3 months to get my enthusiasm back and make an attempt to fix it.
I have several options but to make sense of them you have to remember the van is quite rare, the 4x4s are not common especially the big 416 version and they hold there money extremely well on top of the fact that mine has covered almost no miles, So.....
(1) A recon engine for the Sprinter is £1900 exchange, but only if mine is not damaged (which it is) so that means non exchange price is £2500+VAT+delivery with 12 months warranty, unless you fit it yourself, in which case its only a one month warranty, this is pretty much the same from everyone, i'm not paying over 3k for an engine with a 30 day warranty and i just don't have the funds to get it fitted by a pro on top of buying the engine.
(2) Chuck a scrapyard engine in it, these are still £500+, come with no warranty and being a Sprinter engine 90% of them will be well over 300,000 miles which seems a bit pointless bearing in mind the rest of the vans mileage and the fact it would be worth £10K even before i start converting it to a motorhome.
(3) Buy a car that was fitted with the OM12 and take the engine out, for £3000 I am likely to be able to buy a much lower mileage car who's engine has had a much easier life probably bolted to an auto box and not humping 3 ton of gear about all day, as I don't care if the car is totalled as long as it runs and I can check the engine this seems like the most sensible option as long as the engine is the same which is where i need your help.
I don't know if its the same engine, or if it is, should go for any particular year/model of car?
It doesn't matter if the sump and ancillaries are different as I have all that on my engine and can swap things around as long as the block and base engine is the same so anyone know there engines and can offer suggestions?
Couple of photos just so you can see what I'm trying to get fixed, hopefully to build up into an expedition vehicle.
I'll say thanks in advance for anyone who can offers suggestions.
