spock500
Hi all,
I noticed recently a high pitched squeaking noise coming from the belts/pulley area which could be a worn water pump bearing.
Whilst looking at the water pump I saw what appeared to be a oil lube hole at the top, its quite big probably about 3/4mm across - anyway, I hope its a lube hole as I gave it a good few squirts from my oil can.
Can anyone confirm if this is correct or is it for something else?
