Wackeldackel
- Jul 2, 2014
- Location
- Potsdam, former DDR / Kent, UK
- 1999 Mitsubishi L200, 1989 W124 300E manual LHD, 1993 W124 250D auto, 1980 508D
My W124 E250d died at the end of February, no warning, I noticed a slight ticking from the engine as I left the motorway, pulled in to investigate and the car died as I rolled into the layby. Cue recovery truck home.
Did a few checks (timing chain, cracked injector lines, checked camshafts) then sent car for comoression test. No compression in cylinders 1 to 4, only cylinder 5 held pressure, this led me to suspect cylinder head gasket or at worst a warped head.
So then I strip everything down to remove the cylinder head.
As I'm draining the oil I notice a couple of ball bearings and bits of metal in the oil catch pan. Fantastic
Turns out that the vacuum pump has dumped its bearings and bits of tge arm on the back into the sump, apparently a common problem on the OM60- engines.
