speedwellfane
- Feb 9, 2013
- Audi A3
Hi I am new and need some help.
I hope this is the correct way of starting a new post
I am fitting a OM 606 962 turbo engine in a boat and I need to know a few things.
1 what car can I get a manual solid flywheel from to fit this engine.
2 I am fitting a OM603 N/A mechanical IP what mods can I do to this pump to get the right amount of fuel to give the same out put as the 606 IP. Can I change the elements from the 606 pump to the 603 pump without having it go to a bosch dealer to be set up.
3 What does the vacuum controlled device on the rear side of the 603 pump do it has black vacuum pipes on. and do I need to keep it.
4 Can I just run a vacuum line from the intake manifold to the turbo.
I will possible need more help but thanks for any input.
Thanks Kevin
Thanks Kevin
