OM613 hp pump on OM613 engine?
Martyn_n
Leicester
W124 E320, W163 ML270 & W166 ML350
hi,
Can anyone tell me if the hp fuel pump from a 613 engine would a straight swap onto a 612 engine. They look the same and the rigid hp pipe from pump to fuel rail has the same part number so I’m hopeful. I’m assuming that flow rate may be (20%) higher but otherwise the same part. Any advise would be appreciated.
Oops, obviously the title should be 613 pump on a 612 engine!! Apologies
