Welby
Evening!
Having tackled the replacement of my W211 front bottom ball joints with Eurocarparts Lemforder replacements at 90,000 miles last night, I'm wanting to have a go at other serviceable items with this level of miles such as the poly v belt, but detail of replacing this seems thin on the ground, is this a simple job to do, does it require the pulleys to be replaced which I believe there's two, plus a tensioner possibly? Space seems tight and the belt run complex. I spoke to an MB dealer and £125 seems cheap and I doubt the tension and pulleys are replaced at that value. I've little option to run my MB on a budget.
Cheers
Sent from my iPad using MBClub UK
Cheers
