I have a 2008 280CDI with the OM642 engine spec'ed to 190PS. I understand the 320CDI is the exact same engine but at 235PS or thereabouts. I have also read that the 280CID ecu has some portions "locked" and cannot be easily modified, but the 320cdi ecu can be upgraded further.
What would it take to swap an ECU from a 320cdi OM642 to the 280CDI? I understand at least 3 components need to be swapped -- ecu, key module, ignition unit (anything else)? What additional programming is needed?
Thanks!
Byas
Thanks!
Byas
