OM642 engine stops
tony jr
I have just replaced the airmatic compressor on my 2007 x164 and went to turn on the engine, it started fine ran for about 30 seconds then cut out. I read the codes and picked up p0340 camshaft position sensor A circuit bank1 or single sensor. I changed the sensor and still had the same problem with code p0341 showing together with check component b6/1 (camshaft hall sensor) signal faulty. A friend also picked up a random misfire when the engine cut out. The engine still starts fine runs smoothly then cuts out after 30 seconds. Not sure what to do next. Could it be the crankshaft sensor without a code? Could it be a wiring issue? What would cause the engine to cut out like this?
