D
Deleted member 156365
Guest
Hello everyone!
Will be purchasing the ML320 CDI (2008 - 2010) sometime next year and in the interest of taking good care of the car (pre-emptively) was thinking of doing a DIY clean of the intake manifold/ cylinders without having to take the engine apart. The car I will be purchasing will be around the 100k miles mark, so I do expect there to be a slight carbon/soot buildup.
From the videos I have watched online, Sea Foam spray seems to work wonders with a nice white smoke show to follow by simply bypassing the MAF and placing the spray straw into the throttle body.
Has anyone used Sea Foam spray for this purpose before on their diesels? They also have a formula to be poured into the fuel tank to clean the fuel pump/injectors..
Thank you in advance!
Milo
Milo
