OM642 Higher Fuel Rail Pressure Sensor
SaundersW203
Norwich
Mercedes C320 Cdi
Hello Everyone
I have a v6 OM642 (diesel). I'm at the limit of my fuel injection system, to inject more diesel efficiently, I need to increase my rail pressure. The current fuel rail pressure sensor is 1800Bar, does anyone know of a "bolt on" sensor that is around 2200Bar I can use?
Thanks,
Adam
whatta heck you are tweaking? Are you on limit on injector opening time already? Get bigger injectors, C30 AMG's are good place to start...
I'm not sure c30 AMG injectors would be any better. The OM642 has some pretty good injectors.
I'm injecting 115-120mm3 of fuel. I made an excel spread sheet so I can check my EOI and it's at 3-4°ATDC. I have already added a couple of degrees to the SOI. I'm reluctant to take it further.
I'm running quite lean with regard to lambda (1.3).
Next step is more fuel pressure and water injection because EGT's are quite warm. haha
Rising pressure above normal limits its not normal procedure when gaining power. Icreased injection time can be done until it disturbs mixing before cimbustion. AMG injector do have pretty good addition to flow capacity, what hp levels you are targeting? Fooling pressure is stupid way to do things, if you are heading 'decent' leveles <500 hp I belive you can do it without going excessive pressures.
Basics is: sliglty risen fuel pressue, risen injection times, much more better intercooler, wider nozzles/injector bodies, better performace turbo.
I am not expert of tuning, but done some search before got my C219 remapped, 280HP level
400bhp would be enough. I don't think the pistons/ rods would take much more than that!
Normally too much SOI leads to cracked pistons, bent rods or the head lifting off the block.
Pressure will almost always increase no matter what you do, I have seen it myself. But different tuning methods and hardware limits dictate how much of an increase you get.
I have seen 3L diesel engines make 360bhp 750Nm with just 90mg of fuel. That's quite impressive....cylinder pressures were high though. Or you could use 105mg of fuel and get the same torque and power just with less cylinder pressure and less efficiency. If the engine can take it, why not use less fuel and produce less heat.
In a diesel, more fuel = more heat. Everything is a balancing act, SOI, Duration, IQ, EGT's etc.
I work in engine development, although I only have little diesel experience I've got a pretty good idea what's going on.
I do all my own calibration work (ECU tuning) along with relevant hardware mods/ changes. I'm currently running around 350bhp...
If you increase fuel injection rates and pressure you'll probably find that the pump won't be able to supply enough or at least rail pressure control will suffer.
Have you managed to get an a2l file for the SW then?
smoke is limitig fuel feed in these... like said going over 400hp you can't do pressure/timing alone. Read tuning threads and you will find lotsa info... part list I referred (cooler, turbo, injectors) is close your next actions.
No a2l for this exact software but lots of hours comparing something very similar and then making a map pack....
Stock turbo runs out of puff at 280bhp. I've got a 2365 hybrid.
Already got a larger cooler and associated pipework.
Injectors are more than capable with additional fuel pressure.
Hello SaundersW203, I belive that fuel rail sensor thread is M12x1.5. I find a sensor for 2200 bar, that can allows you to run 2000 bar. But it’s really expensive …
Link : M12x1.5 Rail Pressure Sensor – Torquers Diesel Engine Technology
Many better rail pressure sensor have a M18x1.5 thread. Darkside developements sells a lot of nice sensor, but we need to adapt it on the Om642 rail. Maybe an adpatator M12x1.5 to F18x1.5 could be the solution but it doesn’t exist (or I don’t find it).
Link : Genuine VAG 2700 BAR Common Rail Fuel Pressure Sensor (for example)
You can see on the link that the rail pressure sensor is supplied with a spacer / washer. If they sell it with a washer, I suppose it manage the pressure.
I thought that it maybe be possible to take some plumbing connector with a washer and make an home made adaptor, but it is really patch-up job. I didn't still try to do something like this.
The Om642LS rail has the same sensor thread. So, useless to take it.
(One other problem I read is about the voltage. I'm not sure of what I write, but it seems that not all sensor work with 5V but with lower voltage for little pressure measurement.)
…I just stumbled on this thread as I’m quiet active on ecuconnections. On edc16cp31 the only effect that I have found so far when its question of altering timing parameters, (SOI and/or Duration), was through the duration map. There are 3 SOI maps (with quiet retarded values) and 2 SOI maps (with advanced values)… which seems to be the SOI limiter (well, thats my hypothesis based on many hours of testing and flashing). I tried advancing by 1 degree at some point where egr was mainly active, with no results. Increasing the duration though, provided me some interesting results, GIVEN THAT, boost is also adjusted. Increasing duration only, will only give you high EGT (I do have an egt gage sensor installed at the exhauxt collector). I suprised that Op managed to get results with SOI.
Note : I agree that SOI is the way to go, but in this application/ software something seems to be calcultating the SOI in a different way… probably based on duration, boost and railP.
