- Jul 12, 2011
- Location
- Near Salisbury
- MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
Our W211 320CDi has now dropped into a permanent state of low boost and hence low power with reduced rpm available.
I have scanned it with my iCarsoft MB 2.0 and found the following code:
2510-1 Check component Y77/1 Boost pressure regulator Positioner signals fault
I was able to clear the fault and restore normal running over the last week but the intervals between the fault recurring became shorter until it now will not clear. Normally I would just take it to my MB Specialist but they are very busy and cannot take the car in for two weeks so I am looking at other possible avenues to repair this
Is there any way to be sure it is the actuator unit at fault? On starting the engine and increasing the rpm there is no movement of the actuator arm and I cannot move it by hand although moving an electrical motor and gear by hand is unlikely to work.
I have contacted TurboVanes on eBay who lists a fully reconditioned actuator but I am losing confidence because they have told me a unit they have in stock will fit but when looking at the listing the OM642 320 Cdi 165Kw is not listed, they list a w212 195Kw e350 engine amongst others.
I have asked twice for confirmation and they either did not answer the question directly or ask for the registration number which has already been provided to them although now they have answered and said it will fit and that due to lack of staff they have not updated their listings recently.
The part number from the eBay listing is: G-13 6NW009543 Hella #184909673337 and they say it does not need recoding
This is the item: Mercedes-Benz C, E, S, M-Class Electronic Turbo Actuator G-13 6NW009543 Hella | eBay
Another possible area to explore is having a rebuilt Turbocharger fitted as the car has covered 153,000 miles, There is a company fairly close to me that offer this service and I have emailed them to see if they can offer a diagnosis and also a quote for either supplying and fitting an Actuator or a fully rebuilt Turbocharger:
They are Turbo Specialist, Turbo Repair, Reconditioning & Rebuild
Has anyone used this company by any chance?
Any advice etc most welcome!
Thanks in advance.
Thanks in advance.
