Hello,
I have a 2005 w211 estate with 130K miles. I've been experiencing a whole rage of problems which, I believe, are related to the turbo and inlet shutoff motor. Apart from this the car runs well and I really want to resolve the whole problem rather than part of it.
Here are the main symptoms:
1. The car has been through two oxygen sensors in the last 10K miles.
2. When cold, and under hard acceleration, the engine starts to jerk as if an actuator is trying to engage but failing
3. When the car is left to idle for 10-15 mins it starts to emit large amounts of white/blue smoke, this clears once the car has been driven for a while
4. The engine exhaust is generally quite smoky/oily, especially when idling
5. The car has recently gone into limp mode, reporting a fault with the inlet shutoff motor
The steps i've taken so far are:
1. Replace 2no o2 sensors
2. Removed and cleaned the 'charge air pipe' (?)
3. Replaced the seal between the MAF and turbo
4. Removed the intercooler and drained the oil out if it (there wasn't much)
My main questions are:
1. Will replacing the shutoff motor most likely resolve the issue or should I look at replacing the turbo and EGR valve also?
2. Should I try and clean the inlet ports?
3. If I go as far as removing the turbo and shutoff motor, would it also be worth replacing the seals on the oil cooler as well?
4. Is it worth getting a new cartridge for the turbo and trying to recondition it myself?
Thanks for your help,
Alistair
Alistair
