W204, OM646.811 with 100K miles.
I have been chasing noises on the front of the engine and after having lubricated all the pulleys, replaced the water pump and tested the alternator clutch I am left with a belt tensioner that is vibrating.
It is a relatively high frequency vibration that causes the belt tensioner to blur visually.
The tensioner does not have a damper, but maybe it should be damped by friction which has worn out.
The belt is relatively new and is quite flexible and evenly worn.
Am I just seeing cogging from the motor ?
The crankshaft harmonic damper is fine.
I would appreciate any insight.
