I have a C Class coupe 1.8 cgi M271 engine, I purchased the vehicle with 28,000 miles it is now at 41,000, I disconnected the stop/start system within a few weeks of owning the car purely because I disliked it, When I purchased the car I had no idea at that time there was a timing chain issue . It appears to me by using a system that initiates hundreds of thousands of extra starts on a timing chain and tensioner known to be a weak link within Mercedes engines is utter stupidity. To overcome the moment of inertia there is surely always extra loading on the chain at every start up, worse if the timing chain is not under the correct tension because of a failing or weak tensioner. It is important to find out whether the stop/start system is the cause of the earlier chain failures on the 1.8 cgi 271 engine after 2011.
