Simon_M
Got a leak around the chimney and have been given two options to repair it:
Chimney lead repairs: Option A: (25 year guarantee)
Provide access ladder.
Lift the bottom row of tiles from behind the chimney.
Paint over the existing rear section of lead with fleece reinforced liquid rubber.
Refit the tiles and seal the existing lead flashing into the brickwork.
Clear and tidy site upon completion.
or
Chimney lead replacement: Option B: (10 year guarantee)
Provide access ladder and roof platform.
Remove the bottom row of tiles from behind the chimney and set aside.
Replace the section of lead from behind the chimney using code5 Lead, cut and welded correctly to fit.
Replace the rear lead flashing with code4 lead and seal into the brickwork with lead compatible mastic.
Option B is far more expensive, but has the shorter guarantee. I always thought lead was the best and rubber sheeting was a cheap alternative, which according to price it is. But A has the 25 year guarantee which attracts me to it.
Or does the fitter just have little confidence in his lead work?
S
or
S
