Ongoing Misfire + Power Loss on 2020 Mercedes E220d (OM654) — Anyone Faced This?
akhera1
Hertfordshire
E Class 220d 2020
Hi everyone,
I’ve been battling a frustrating and unresolved issue with my 2020 Mercedes E-Class 220d Coupe (OM654 engine) for months now, and I’m really hoping someone else has experienced something similar.
Symptoms:
  • Cold start misfire and judder that lasts 1–2 minutes, then settles down
  • Occasional loss of acceleration after driving for ~30–40+ minutes
  • No dashboard warning lights
  • No stored fault codes after diagnostics (aside from a P0101 months ago)
  • Fan sometimes stays on after shutoff (rare — once every 6–8 weeks)
Timeline of events:
  • March: Took it to a Mercedes specialist due to one-off misfire and fan staying on. No codes, but they changed fuel filters and air filter.
  • Next day: Power loss issue appeared — would take longer to reach speed after driving for 30+ mins. No codes.
  • April: Got a P0101 code. Cleaned and later replaced the MAF sensor.
  • After MAF change: Cold start misfire began, and it has now become consistent.
  • May: Had a full A5 + gearbox service done and replaced the MAF at the same specialist. Misfire got worse. No codes.
  • June: Took it to another Mercedes specialist. They ran smooth running and cold start tests — still no codes but confirmed the misfire.
  • Took it to a third garage (well-reviewed local) and now they believe the issue is mechanical, not airflow/sensor related. Their diagnosis is worn tappets (lifters) and rocker arms — possibly even the camshaft.
Other notes:
  • No coolant loss (rules out EGR cooler leak)
  • MAF is new and OEM
  • Fuel filter change seemed to be the moment power delivery changed
  • Misfire began immediately after MAF was changed
  • Garage says the lifters may be bleeding down overnight, causing rough valve operation on startup
Has anyone else with the OM654 engine (or similar diesel Merc) experienced something like this? I’ve been chasing EGR, injectors, glow plugs, and sensors — and now suddenly it’s a top-end mechanical issue?
Would really appreciate any input before I authorise a major repair.
Thanks in advance.
- this is a video of the engine shaking on start
This is a video of the engine on cold start
You don't mention the car's mileage, but valve and camshaft troubles have been reported on these engines. It might be worth a search on YouTube.
Ernie
Difficult to tell from video, but sounds like worn camshaft rockers to me. Very common on this engine. “Plopping” sound in air filter box on tickover is dead giveaway
could you plz tell me what was the problem it seems Rackers and Camshaft issue mine doing same but not juddr i been quoted today for £2200 but mine is not that serious
Mine was the MAF sensor that was recently installed was not fitted correctly allowing an air gap causing the car to misfire
