I would echo this, how long does it take for the coolant to disappear? If it's less than a couple of days then that's far too much to be leaking only into the engine, your engine would have blown up by now plus it's also much more common for the coolant to be leaking elsewhere. Have you checked for damp patches under your car when you park it? Also try running it for a few minutes and then look under the car, you might see where it's leaking from.What period of time are we talking to loose the headertank full ?
Either way its not right but if it was the filler cap wouldn't it go straight away?
Hi it takes roughly 2 to 3 weeks.I would echo this, how long does it take for the coolant to disappear? If it's less than a couple of days then that's far too much to be leaking only into the engine, your engine would have blown up by now plus it's also much more common for the coolant to be leaking elsewhere. Have you checked for damp patches under your car when you park it? Also try running it for a few minutes and then look under the car, you might see where it's leaking from.
If it takes longer to leak away then open the oil cap and see if it's oil coloured (either golden or black), if it's milky white then coolant might be mixing with the oil and creating a frothy emulsion and then that might be a much bigger job / sell the car.
The car had no issues before. Radiator cracked, MB replaced it for 1100, car is out of coolant ever few weeksRadiator cracked - can you say with any degree of certainty whether it was losing coolant before the radiator cracked, ie is it an old problem or has it all come about since the repair?
Still quite quick. If you can't see a leak and you aren't that attached to it, I'd say trade it in at Brentford, if they think the car is fine let them offer you top dollar for itHi it takes roughly 2 to 3 weeks.
The vehicle was topped up twice after the radiator replacement. Their suggestion was to keep topping it up. I doubt the tank can be totally empty due to air pockets.How many times did you top it up so far? Perhaps they didn't fill up the system properly and left air in the system?
Either way, a coolant loss problem that started after they swapped the radiator, and they wash their hands off it... not very professional IMO.
