Outlook Help Required
crockers
North Wilts
XC60 MY2014 SeLux Nav plus lot and lots of toys...
Hi
For some reason Outlook wont open. I have tried using the Office disk to repair Office and Word and Excel are fine. I think I will have to remove it all and reinstall it.
My problem is I will lose all my emails unless I can find the file that they are stored in. Is this a PST file? If so where would I find it on my laptop?
Thanks for any help - as I have all my holiday emails in there and need them before we go away.
Try here.
C:\Documents and Settings\<user_id>\Local Settings\Application Data\Microsoft\Outlook
Copy to somewhere else before installsing then copy back.
N.B I usually change the default location to an e-mail folder in my documents (get's backed up then).
Mine lives in C:\users\temp\appdata\Local\Microsoft\Outlook
It's probably a hidden location, and my laptop is hooked to a server so that might affect the location.
Cheers David & Stevesy - found it :thumb:
No idea which one is the right one so have copied all files.
Have you tried running scanpst?
That will sort out any corrupted pst files.
Hi
be careful as I had similar happen years ago and couldnt open the copied back files.
have a seach on ms help sites, as there is a correctway to do it.
I backed up the files onto a USB drive. Deleted office 2007 and reinstalled it. Outlook not only worked but found the original files and all is sorted. Panic is over phewwww.
Thanks for all advice. :thumb:
