david b said:Just bought a C-class 180 avantgarde, how do I change the small K/P/H
display in left hand corner of dispay to outside temp, is it possible, handbook says so , BUT NOT IN UK?
I think it's more of a software/programming issue than hardware or wiring. UK cars (W203/W211 etc) are configured to permanently display speed in km/h on a small ancilliary display where as EU cars allow their drivers to choose what the small display shows, e.g. outside temp. It's probably down to some pan-european law about the metric system.pluggers said:A thought ocurred just,has the car already got an outside temp sensor located in the bumper?Might be a thought if it aint got one it could appear to be disabled.
Steve_Perry said:Fuzzer, did you get the Star man to reprogram your car's ECU to a different country other than the UK?
S.
Yup, apparently you can do the same with facelift W202's as well. Maybe your instrument cluster has to be changed in someway? in addition to the main ECU?fuzzer said:Indeedy , my car is set to netherlands and it still doesnt want to change.
In case youre wondering ... its set to netherlands so the alarm beeps when you lock it and open it
Really ? I need to find an excuse to call out a Mobilo person with a star machine then !!Steve_Perry said:Yup, apparently you can do the same with facelift W202's as well. S.
Yup, K. and Nick should know, I think a few members at Benzsport have done this mod.sym said:Really ? I need to find an excuse to call out a Mobilo person with a star machine then !!
Beep-Beep !
S.
I think the guy at benzsport had his set to Norway, did the same thing IIRC.Steve_Perry said:Yup, K. and Nick should know, I think a few members at Benzsport have done this mod.
smiff said:Oooh - How did yo uget yours up and running pluggers - mine's got the display in, but wasn't picked as an option so I got no temperature sensor/wiring and the displays just dark ( But if you look carefully in the right light you can see the outline of the LCD numbers ). Would love to get it working...
Stew.
96' w202
