Paul64
- Jun 13, 2003
- Location
- South of France
- 1995 W124 E300 Diesel estate (250k miles), 2008 CL63 AMG, 1969 Triumph 2.5PI, 1975 Triumph TR6
The display has stopped showing the outside temperature on my 300CE24 however, when starting the engine up, I do get a +38C indication for a couple of seconds.
Can I assume the sensor has gone rather than the display? Can I cut and solder in a new sensor or will I have to run a new cable complete??
I also have a small problem with the ventillation fan speed control. Sometimes, if I turn it on to the first fan position from "0", it doesn't start but, if I leave it for a couple of minutes, it eventually decides to come on and runs normally after that. If I use position 2, there is no problem at all....
Occasionally, the starting of the fan seems to coincide with the sound of a vent flap behind the dash moving into position. Does there have to be a "start" position for all the flaps before it all fires up??
Thanks for any ideas
