Hi all,
I wonder if anyone could shed any light on my issue.
I have a C63 AMG, 2012. There are 2 things id like opinions on, both to do with the ambient temperature sensor, firstly, the displayed temperature always seems to be too high, for example this morning the car was showing 14 degrees c, even though it was only just above freezing ( the engine was cold, so couldn't have been picking up heat from there, and my work van was showing 1 degree c ). This reading does change, as in its not stuck on 14, but just always seems to be 10-15 degrees higher than it should be !
It has been doing this ever since i bought it a couple of months ago, I have changed the sensor at the weekend, and it still shows it as being too high!
The second thing is i haven't worked out a way of having the temp showing as i drive, it shows up when i first get in, then disappears when the car is going, I checked the handbook and the section where it says you can swap between digital speedo and temp in the lower permanent display, also says it can't be done on uk models.
Any advice or thoughts much appreciated.
