Hello,
I (more or less) followed these wonderful directions about how to change the ATF fluid on my 1997 E420.
I bought 9 quarts of ATF fluid, and while the oil was draining out of the left cooler pipe (after removing the banjo bolt) I was adding oil to the tranny pan so that oil would come of the torque converter. Once clean oil came out, I buttoned back up the banjo polt and put the rest of the 9 quarts of ATF fliud in.
I emptied in all 9 quarts of ATF fluid. I did not measure how much fluid I took out.
I bought the tool to measure how much oil is in the ATF, and (even cold) it is over the black dip stick.
so my question is, do I need to empty out the extra oil? do I need to do it ASAP?
Your input is appreciated!
