I have a 7 seater P reg minibus that will only run in saftey mode, (1 gear) all ecu, clutch housing, gear box etc are working fine, does any one else have this pobblem?Have absolutely no idea what you are talking about, sorry![]()
My trend has gone into saftey mode all functions are working is this common
Lots of people would love to help you but do need more detail like:-
Make and Model of minibus
Year of first registration
Engine size and type
Gearbox type
Current mileage
If you can give us these details I'm sure one of us will be able to help
Here we are Mercedes Viano TrendI think that Trend was a model variant (like Elegance, Avantgarde etc) on the V Class...
Thank you for your interest in the Mercedes-Benz SLK-Class, particularly a Mercedes Viano Trend.
Thanks im 1st timerLots of people would love to help you but do need more detail like:-
Gearbox type
Current mileage
Thanks, Its a petrol 80,000 miles. I've been told its limp mode. I have taken it to a main dealer for a diagnostic and they have given a very poor recomondation. I have had the ecu, and gear exchange tested and they are working fine, it seem to be a stange thing although there seems to be a few around with similer problems. It is always running the same in 3rd all the time. What is STAR?ah, that's a bit better!
Firstly, welcome to the forum.
When you say 'safety' mode I will assume you mean 'limp home' mode?
Is this diesel? There could be any number of problems. Could you describe what happens? How the engine reacts/doesn't react? If you turn off the engine and on again is it ok or does it re-occur soon after?
Think your best bet is to get it on STAR and get the codes read.
Where are you located? Someone on here should be able to find you a local Indie garage nearby.
Good luck![]()
Hi I'm in tunbridge wells kentStar is the diagnostic programme that main dealers and good indies use.
Didn't your main dealer connect it up to finf what was wrong?
You wre asked where you are so that we could recommend a good local indie to help you out.
