hi,sorry if this has been covered before but i have an intermittent e.m.l and my reader is giving p0171 code-engine running lean bank 1.
i have searched and found that there are 2 breather pipes that are the usual suspects for this fault,i have one(part number A2710181282 CRANKCASE BREATHER PIPE) but need the part number for the other common failing breather pipe which sits under the airbox,
has anyone ever changed these and can give me a part number or any other advice on this or description of the pipe..apparently it is a very common fault on m271 engine thanks in advance
