Clayton1212
Hi Guys
Happy Newyear
My wife drives her Mercedes A180 W176 (2017 120.000km.) on the way to work, she has to pull into the emergency lane because it won't take gas.
She turns it off and on a few times and can drive home (without turbo pressure),
the engine light is on though!
I put my OBD2 tester on and get the following error codes:
Car Scanner ELM OBD2
Version: 1.101.9/401019/GP
DTC report
Connection profile: Mercedes-Benz OBD-II / EOBD + AT (CAN)Date: 1/6/2024 10:21:16 AM
VIN: WDD1760121J638488
OBD-IIOBD-II
DTCs: 3
P0299 [0x0299]
Turbocharger (TC)/supercharger (SC) - low boost
Status: Confirmed
P247A [0x247A]
Exhaust gas temperature sensor 3, bank 1 - out of range
Status: Confirmed
U0401(86) [0xC40186] Archive (inactive)
Invalid data received - engine control module (ECM)
Status: Test failed since last DTC clear
Engine control unitEngine control unit
DTCs: 5
P0638(77) [0x063877] Archive (inactive)
Throttle actuator control (TAC), bank 1 - range/performance problem
Status: Test failed since last DTC clear, Test not completed during this operation cycle
P0638(73) [0x063873] Archive (inactive)
P1544(98) [0x154498] Archive (inactive)
Status: Confirmed, Test failed since last DTC clear
P2263(22) [0x226322]
Turbocharger (TC) boost pressure/supercharger (SC) boost pressure - performance problem
Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
P148E(22) [0x148E22] Archive (inactive)
Transmission control unit
No DTC found.
ABS control unitABS control unit
DTCs: 1
C0734(00) [0x473400] Archive (inactive)
Steering
No DTC found.
I've searched and found it probably has something to do with the Throttle sensor, I've also checked the plugs/wires and hoses, nothing to see, do you have any experience with the above error codes?
and possibly Do you know where the throttle sensor is located?
Thank you in advance from Denmark
Best Regards Morten
Happy Newyear
DTC report
OBD-IIOBD-II
DTCs: 3
P0299 [0x0299]
Status: Confirmed
P247A [0x247A]
Status: Confirmed
DTCs: 5
No DTC found.
DTCs: 1
Steering
No DTC found.
Best Regards Morten
