ex4x4
- Oct 21, 2013
- Location
- County Durham
- 2006 C230 se - 2004 CLK200k - 2010C180 estate - BMW X5
Hi folks - thought id share my concerns and hopefully glean some infomation regarding my CEL light.
My latest MB to join the paddock is a C230 2006 - non Komp. it has the V6 2.5 engine.
shortly after buying it the CEL came on. I checked it with my Autel scanner - which showed a P0432 and P0422 fault.
The fault is saying basically the down stream O2 sensor is giving a below threshold reading for both branches of exaust.
these two fault codes are the same - just for different banks of the V engine exhaust system.
Now for info - the engine runs sweet as a nut, no smoke, no hesitation, pulls like a train and MPG appear normal - 29mpg combined.
Ther two cats do not rattle when banged with heel of hand.
the O2 sensor wiring appears undamaged.
the fault code will clear and not return until a certain part of a repeated journey. IE I can drive around town and lower speed roads all day without fault. The fault appears when driving at motorway speeds and cruising.
I have checked through and vac tested Vacuum hoses. Evap solenoid not passing. secondary air system functioning and solenoids,diaphragm units operatiing.
Im finding it hard to believe that both cats would fail at same time and then only throw a fault at high speed cruising with an engine running at normal operating temps.
Ive measured O2 output voltages on sensors with my Autel unit - down stream sensor voltages do vary from 0.8v to 0.1v every few seconds and cat inlet /output temps differ by 60-70'c
As a test I have fitted a shroud / fooler to one of the banks O2 sensor and it reads 0.1v constantly - but still throws a fault for both banks.
spark plugs appear and normal greyish white - but have not been replaced. Air filter and oil filter have been replaced and a good dose of redex through system.
What else can I check before buying new cats.
