TokyoKazama
Hi guys. A few days ago my check engine light came on (A class A180D 2016). Got it checked out at a garage. The guy said for £40 he would take out the sensor and soak it in a solution which could fix it or for £200 he could replace it entirely whereas I took it to another mechanic as well and he was baffled by the idea to soak the sensor and instead suggested to take out the filter and manually clean it using solution for £260 (not the same as a dpf regeneration which he said is a scam because it's a short term solution). He also said failing that he would suggest to replace the sensor.
Either way I'm really confused as to where the actual issue lies and don't want to spend hundreds of quid fixing one thing when the issue lies with the other thing...
