Retepfb
- May 7, 2017
- E250 CDI Avangarde Estate Blue Auto 2012 and Vaneo 1.6 Auto 2006 Wheelchair conversion
Vaneo WDB 414700 - CAN bus fault P0600 - cannot communicate with the Auto Module A61. MIL and BAS/ESP lights.
Clear and it comes straight back. Car stuck in Limp mode 2nd gear.
MB specialist has also checked and its possibly going to be a long hunt to locate the issue so I am stripping out the trim to access the main wiring and carry out initial checks on whatever I can including ground points. battery is good hardly drop voltage when starting. So first off trying to locate where the CAN cables come together on Z37/2 and Z37/3 connector sleeve - engine compartment, and in a different place Z37/4 and Z37/5 connector sleeve interior.
Removed the glove box, trim and floor covering to expose what I believe to be the engine compartment sleeve where the ESP module is located with some relays. Access from both engine and interior. Have not unbolted from the inside yet but looking at this assembly I cannot see any single plugs that look like a CAN distribution BUS.
I know that I will probably have to get to the Auto box connector which is located right at the bottom behind panels of some type just to test from there.
Any assistance on locations of the connectors and any easy way to get to the areas/components required.
Thanks in advance
Peter
Thanks in advance
Peter
