P2095 / P2136 Error Codes Camshaft Position Actuator Circuit High ?
Paragon1970
UK
Mercedes 2008 e280 | Audi TT
Hi Folks,
I just received a generic OBD2 bluetooth scanner, the cheap ones of ebay and am running Torque on an Android phone.
I started the car from cold and received the following two errors:
P2095 - Powertrain
B Camshaft Position Actuator Control Circuit High bank2 c
P2136 - Powertrain
Throttle/Pedal Position Sensor/Switch A/C Voltage Correlation.
Can anyone explain what these mean, particularly the first one?
Something else to note is that I just purchased this car from a dealer and it has three month warranty or at least thats what I was told.
The other thing I have noticed is that the coil light comes back on for around 30 seconds after starting. So guess this could be a bad glow plug or faulty glow plug control unit?
Any advice would be most welcome.
Thanks!
Wonder if the P2095 actually = 'self adaptation L cyl bank for enrich at idle load above limit' ?
Should have mentioned the model of vehicle!
E-Class E280 CDI 2008 7-Tronic Estate
Wonder whether the P2136 code actually relates to a faulty glow plug.
Found the following info for an earlier model 2005 E320CDI:
P2133 Glow Plug Failure Cylinder
P2134 Glow Plug Failure Cylinder
P2135 Glow Plug Failure Cylinder
P2136 Glow Plug Failure Cylinder
P2137 Glow Plug Failure Cylinder
P2138 Glow Plug Failure Cylinder
Cheers.
