Dazzer123433
Hi guys I’m looking for some advice, I have a 2011 Sprinter 313 (ex dhl) 310k miles. over the past 3 months it has begun to shake/vibrate at 2200rpm any thing after that and it’s fine if you accelerate hard it also seems to not vibrate as much, there was no eml on, it went into the garage and had, wheels, tyres, discs, 02 sensor, throttle body, EGR, DPF, clutch, dual mass flywheel, prop balanced, gear oil change, full service with Merc parts it still hasn’t solved it 2 weeks ago it went into limp mode EML came on with code P2263 (the vibration stopped) it was taken to a garage and they diagnosed it as a faulty turbo, new turbo fitted and more expense and the vans still in limp mode with the same fault code, garage have said they have done all they can and now they don’t know, I’m stuck now as I need the van for work and can’t afford to keep spending money on it any help or advice would be greatly appreciated
